Hammermechanicman
Never under estimate a good pipe wrench and a 6 ft. Pipe "torque amplifier"
At least the Oregon 04-015 are under $2 compared to the MTD 712-0417A $5.15. You could had been dealing with the JD M123569 that are around $7 ea and there is currently no after market for them. Just had to buy 6 of them here to replace the faulty ones on the Stens spindles that I brought for a customer.
usually, i do go the the shop where i bought it from, but i'm not driving 40 miles to get a couple nuts when i can have them sent to my house. My truck is a Hemi, and it uses quite a bit of gas, so, shopping on line for them was cheaper than driving that distance. Besides, if i walk into the shop, i'd spend more money on other stuff.Ever heard of supporting your local shops? IF you were local to me and came in it I would have sold you the Oregon nuts at $1.95ea inc tax. The only time I sell the more expensive nuts is when the customer insists on OEM parts.
I only have 13 of in stock currently
repeat what you did with the breaker bar,only go the other way with it,then reverse it again and try, also a strong impact wrench would probably work2016 CC proz100s EFI 60" deck
i'm trying to remove the spindle nuts. I put a 4 foot breaker bar on the nuts, and locked the blade in place with a piece of wood. I practically jumped on the bar and i can't seem to get those bottom nuts loose! i sprayed them with penetrating oil, let them soak, but they won't give. I can;t use heat because of the oil seal on the spindles.
The manuals all say they are right hand threads.
Any suggestions would be appreciated.
I really need to change these blades.
