Gary House
I have a Husky 24v48 riding mower with a Briggs 44n877 engine. After mowing one day I heard a loud popping noise and discovered something happened to the seal from the sump to the block. I removed the engine and found the sump was cracked. I bought a new one and installed it but when I started the engine it would run wide open. I adjusted the governor as indicated in the repair manual but it didn't fix the problem. I was wondering if I somehow didn't set the governor mechanism in the engine to the proper position. I'm just not sure. Any help would be appreciated. Thanks.
