Hicksvilleshick
So I realized a dream and stumbled upon a deal for a dixon ztr black bear 34" commercial grade mower. Bought it drug it home and had to fight with the safeties on it, to get it to move again (not an issue during test drive) and used it to shuffle trailers around the yard and totally murdered some leaves piled up in the corner. Well it was apparent there had been a leak around the pumps, the guy I bought it from said the tank was pushing fluid out, but was full full so he pulled some out and he hadn't had a problem since, and couldn't find any leaks.
Today in an effort to trace the leak, and see if it was actively leaking. I loaded it up and took it to the carwash to rinse it down (low pressure, not carwash pressure) in an effort to find any leaks if it's still leaking. Cleaned up real nice. Got home and went to back it off the trailer, and no right side. It was the weaker of the sides, meaning the right stick would have to be 1-2" further forward to maintain straight driving direction. (If held at the same point, you'd make a long right turn) but that was the only issue prior to this I had noticed.
Initially when trying to back it off the trailer it was making some noise but now, nothing. Left side works just fine. Was a pain to wrestle it off the trailer and into the garage.
Not new to running hydraulics, but haven't had to diag them much. My question is, where do I start? Pointers? The tank has fluid, and appears to be same level as when I bought it.
Replacement pumps look to be about what I spent on the mower. I lined up a guy to make me new hoses if I had found one to be leaking which is why I was cleaning it up.
Thanks in advance!
Thanks in advance!
