casual observer
- Dec 22, 2022
- 3
Hi,
After reading your issue, , I think your problem is actually your starter motor circuit, could be electrical issue or a broken part or slipping part in the starter motor. A starter motor should always have enough guts to crank engine. The fact that you can turnover engine without sparkplug, but not with spark plug installed, when you get max compression, Also over tightening valves ,even slighty was letting compression out of engine, which allowed to crank.
I suggest you reset all of your original overhaul like you had it, they check out starter system, bad battery, wiring, starter motor, slipping overrunning clutch in starter motor.
If you can crank engine with starter rope, try that.
