- Nov 29, 2014
- Threads
- 64
- 24,729
They only crack if the bolts come looseI had well over 1000 hours before my lawn tractor engine developed serious problems. And, even then, those problems were not normal ones but ones that were caused by poor engine design and never would have happened to a well-designed engine. I am talking about the Kohler Courage 20hp engine, otherwise known as the "bucket engine". The problem is the "bucket" design of the crankcase that is its weakness. With age, it develops a crack in the crankcase sidewall that isn't repairable.
The crack is very repairable I have done about a dozen of them in a variety of ways from epoxies through to welding.
It is an easy fix
Only affects some mowers , got lots now with better than 2000 hours running strong
Yes it was a design fault but it was also covered under warranty for around 10 years
