Toro Time master 30" Peerless Transmission problem
cgm
Does anyone know how to rebuild a Tecumseh peerless 300 series transmission from a Toro time master mower? There seems to be no diagram or any information that I found on repairing this animal only just throw away and buy a need one. Thank you for your help in advance.
Here is only thing I found on the 300 series. Otherwords they are not serviceable.
shadetree#1
I've re-built different models of the Peerless that are not recommended as serviceable. (patience is required) Post up some pic's of your transaxle or the model of the tractor it's used in. Tecumseh/Peerless has a free service manual but that one is not listed in their manual, because it's not recommended it be opened up.
BUT only reason I rebuilt them is
I usually had two or 3 donors for parts. sometimes have to take 3 to build one.
Did not have access to a lawn tractor with a good transaxle
The lawn tractor needing the drive was know to be a good one.
Normally you will be better off cash wise to keep a eye and ear open for another lawn tractor or one that engine is gone and has a transaxle.
  • Like
Reactions: cgm
