fishingman48
- Oct 30, 2022
- 7
Have a LTS2000 bought used from backyard repair shop guy seem to know his business / however when i started using mower it ran fine for about 45 min. after that started running high & then low like running out of gas/ gov armature fluctuating repeatedly some back firing and stalling / choking out/ leave for a bit would start back up run fine for 5 min then start all over again /
Had carb & sensor replaced" brand-new" started up ran fine how ever got home ran it for around 15 minutes and died out tried starting it no fire just turn over waited 5 min & tried it started up ran for a bit then started choking outgain left it for like 20 minutes came back it started right up ran like a champ 5 minutes later starts choking out again just like it did prior to installing new carb & sensor.
Plenty of fuel through line to carb air filter new, all throttle arm's work nothing sticking outside when using throttle, new fuel filter & as stated fuel lines are clear.
My question is would the ignition switch have anything to do with this?
or coil since new carb & sensor
