1 Lucky Texan
- Feb 26, 2013
- Threads
- 24
- 575
what's up with that?
bought a coupla used batts from ebay and one is Elite.
Supposedly, you can scan the code on the battery to download an App that will let you communicate with the battery to see its status or even disable/lock it so that if someone steals your battery they won't be able to use it. Seems like a lot of useless mumbo jumbo to me, and I've never tried to use it on mine. What is useful is that it also works as a USB charging port.what's up with that?
You have to press the green test button to activate the USB charging and Bluetooth functions....aaaaaannndddd the port doesn't seem to work.
I have these 2 Eufy security cameras. Few months old and the one at the front door needed recharging. Tried to use the long cable I bought and this used elite battery. Wouldn't charge. Got my 60v battery and the inverter I bought for it and charged fine with that. Saved me from dismounting it and haveinf to futz around with adjusting the aim again.
yep, presently charging backyard eufy camera. thanx againYou have to press the green test button to activate the USB charging and Bluetooth functions.
