chillen_chris
I have a 2020 maverick 60 in cut I was wondering if either buying bigger tires was ok cause $270 for 1 tire is crazy. Or can I replace the rim with a more common size with no issues? Has any one done this?
Thank you for the advice. I will probably buy new wheels to get a more affordable tire. I can get a full set for 175.00 that would give me 2 extra tires.Mower tyres are very slow moving stock , bulky and go off in storage
That makes them expensive to supply as replacement parts
Being made in short production runs makes them even more expensive .
So those prices are quite reasonable
If you change to a different brand let alone size then both must be replaced or you throw the mower out of level .
ATV & Quad bike tyres are usually less expensive as there are fewer sizes so they get made in larger production runs and they are replaced a lot more often then mower tyres.
Shops that sell a lot of off road tyres will also have lower prices
Down side is ATV tyres have more aggressive threads so require a lot more care when turning to avoid ripping up the grass .
23/11.00-12What is the original tire size?
You can probably buy 2 new tires that will work fine. Golf cart tires. ATV tires. Kenda or Carlisle turf tires should run about $90 to $120 each.Thank you for the advice. I will probably buy new wheels to get a more affordable tire. I can get a full set for 175.00 that would give me 2 extra tires.
You can fit a 23x10.5-12 easily. A 4 ply rating at minimum. The Bad Boy Reaper tires are a specialty item. Toro and Hustler have similar tires. Bad Boy and their dealers would love for you to buy exact replacements.23/11.00-12
