D
		Deleted member 97405
Guest
Quality of cut is all about air flow. Gator blades don't create enough lift in certain grass types because the wing tips are serrated, which decreases air flow. The discharge chute is also choking the air flow. Put a new chute on it, OEM side discharge blades (or OEM mulch blades if running a mulch kit), set your high rpm at/about 3300, level the deck, and you should be good. I've seen this issue many times over the years, and this has 100% fixed everyone of them.
