Here is the actual Husqvarna technical school teachers videosHow can I tell if it is properly venting?
That what I suspected but I played it safe with something I know will not harm these rubber parts. Usually I clean the outside of carburetor before putting them in USC using the same fuel mix the equipment runs on as I know it should be safe to use for the carburetor and of course not good for the user; unless, you take precautions.@StarTech I have used the Walbro carb cleaner and can confirm that it is not rubber safe. It will swell the check valves. Seems to be less harsh on the carb than the normal off the shelf carb and choke cleaners but is not fool proof.
And most tank filters are around 150 micron whereas the internal screen in the carb is roughly 75 micron. so it will catch stuff that will go right through the tank filter.
