James K
I have a Husqvana YTH2242 with a Kohler CV675s motor. It started smoking so I changed the head gaskets after seening all the info on head gasket problems and upgraded gaskets available. That went fine but after putting it all back together it spews gas out carb and will not start. Is it possible that moving the carb around caused a problem with the carb?
