All good points and things I think about regularly. We mainly have the land because of the quiet and space it provides. But to your points, I don't need or find 5 acres of lawn very useful. We have a 3/4 acre pond and have been growing the size of our garden over the last 5 years or so. I've been considering making xeriscaping areas, permaculture berms or plots for growing more food and taking away grass area.
The other option I've been considering is getting a tractor to develop garden plots and keep the mower I have. If I only had a few acres to mow, the current mower would be more than sufficient. It's just figuring out if I want to spend 10k on a new mower or 25k-30k on a used tractor. But the costs add up when adding irrigation and other things...
Thanks for the ideas.
IF their is a local permaculture or native plants group , environmental restoration group , near by, join them .
Down here a lot of such groups have access to large labour force of volunteers + plant + equipment and even more important experteese
Down here if you are returning 2 acres or more then the Society for growing native plants will provide both the labour & the plants either for the cost of meals or at a nominal small cost .
Greening Australia will do the same but you are required to sign a covernant over the land for 25 years that it will remain in the new " green" state & not be redeveloped as the government subsidizes them.
This of course affects the property value but as of late it has been increasing the value rather than decreasing the as was the case 10 years ago .
And then there is LandCare Aust but they are more about public open space .
I understand your motives
Most of my customers are immigrants ( or their children ) from Europe and they all have the same reason for staying here "space,,, matey, the space "
As one of the Maltese ones put it , I like it that I don't know when all of my cousins or neighbours are having ***, farting , going to the toilet, argueing and what they are cooking every meal .
My workshop is in a corner of a friends 1000 (ish) acres being the old farmhouse that is subject to flooding they built a new house higher up which is the closest neighbour at 750 metres , there is 300 meter river paddock then a 400 meter park before the back of the nearest neighbour to the east, a 500 acre hay paddock on the other side of the road so yes I appreciate the solitude although the road gets about 4,000 vehicles a day .
Even better is the christmass tree plot that got away so I have a forest of 40' to 60' pines 100 metres away that is a delightful relief on the 45 deg (C) days as it can be as much as 15 deg cooler under them.
I see lots of older stand on loaders / diggers that are very cheap in the USA that could be used to do just about everything you would need to do, abeit slowly as most are just a 20 to 30 HP V twin hooked up to a single hydraulic pump.
Most come with a full compliment of impliments including both flail & rotary mowers / slashers .
I have 4 Kangas and 2 Dingos in the service run , they were originally the same company but the partners split up & one opened up in opposition .
