You can put it anywhere but there must be a ground wire to the mounting bolt
Remember electricity needs both a + and a - connection
I will run that test. Thank you again for all your help.Should work.
The test is of course to check the battery voltage engine off then again engine running
Running it should be 13 V or better although it might take a couple of minutes to get there
