racecar1854
2000 345 JD I own started skipping in the spring only when not under load. While mowing no skip. How ever this last week the skip got bad at all times. I pulled the left plug wire while running barely made a difference. I pulled the plug, it was black and only maybe a month old. Put a new plug in and skip was still there but useable. So I assumed a bad coil. Replaced the coil and cap with JD Denso and I ran great for about a half hour then the skip came back. It doesn't smoke or use oil. 1400 hrs Is it a lean skip or something else ?? Thx New Member
