675exi no spark
Mchernecki
I have a 675exi model 103M02-0008-F1. I was cutting the grass when it just stopped. I tried to start it and it fired up for half a seond and stopped. The next day it would not fire at all, tested it and no spark. I bought a new coil and again it fired for half a second and again no spark. Any ideas?
Scrubcadet10
Moderator
Staff member
test for spark with the small kill wire unplugged from the coil.
Ok, disconnect the wire and it runs fine. Just can't shut it off without pulling the spark plug boot.
You are onto something. Something is grounding out the coil. Need to see what it is.
