Yes I did (I learned that from YouTubeDid you test it by removing the kill wire & checking for a spark ?
Thank you! Good tip!If you need a part or parts, might try Parts tree . com
You're right.unless you accidentially hooked it up backwards it should have made no difference
The coil has a chip embeded and they just die
Yes, I do live i Europe. This engine is in a Ransomes Triple 18 mower.I’ve been trying to find this engine for the last two days with no luck. To me this means that you must live in Europe and we have little info on these units. Two questions I have. Is your engine number GH-250 or GH250? Second is it possible for you to post a picture of the bad ignition coil?
Finally I managed to remove the coil (not easy, I had to dismantle a whole lot of parts before that…).I’ve been trying to find this engine for the last two days with no luck. To me this means that you must live in Europe and we have little info on these units. Two questions I have. Is your engine number GH-250 or GH250? Second is it possible for you to post a picture of the bad ignition coil?
