Replacing blades on 52" deck
longsam1950
Model # 939124
I removed the blades from my Big Dog Alpha. They are basically flat. I have a set I bought for my 50" Cub Cadet that are the same length, and have the same diameter mounting hole. They are raised in the middle or offset. Will these work on my deck? Thanks
Welcome to the forum!
🚜 I'm going to move this thread over to where more people are likely to see it.
They will have a different air flow profile
This may suit your grass better or it might be worse but you will not know till you try them
In any case they will not hurt anything
I put one on the deck and the cutting edge was lower than the bottom of the deck. I thought it might create a safety issue??
