mauisundevil
Okay, I tried searching for my problem using various key words on this site, got nothing. Hopefully you masters could help me out. I wrench for a living so diagnosing problems with various test equipment is not a problem.
First, I have an LA115. It starts fine and moves forward and reverse fine. Strange part is I am able to get off the seat and it will still run. I am able to unplug the connector at the seat switch and the engine will still start, run and will not die out. It did not do this before. Before, with the engine running, the engine would just die out when I get off the seat. Now with the engine running, the engine will die when I move the engagement lever forward to start spinning the blades. I checked the pulleys, they all spin fine, none are frozen. I unplugged the switch at the engagment lever, the engine will not start. I did find some water dripping form the seat. It has been sitting out in the rain lately. So the seat got soaked.
After some research in the owners manual I found on the John Deere site, it mentions a "Safety Interlock Circuit". Does here have a wiring schematic of this circuit? If I can't figure it out, I will end up just ripping out the wires and make my own wiring loom but get rid of all of these safety stuff.
