corvairbob
- May 23, 2013
- 136
my brother dragged his poulan pro 8.5 hp flathead engine snowblower over the other day with what the repair shop said was low compression. i put a gage on it and it has 30 psi using the rope. he was complaining of it not having the power it used to have and he said it sounds like the engine is slowing down when it gets into a snow load.
so i first hooked up the tester and did a dry test 30psi then i pumped 5 pumps of oil and pulled the rope a few times to get the oil around the cylinder and i had 35psi then i put oil on the valves and the same 35psi
so i went to my 9hp tecumseh flathead and i got about 40psi and no change with oil
so i went to my ohv tecumseh and did the same and got about 50 psi
so i'm thinking this is due the the decompression causing the low compression for cranking with the rope and the electric start.
he thinks he wants me to rebuild the engine which is rings and i may grind and lap the valves, but i wonder if i should be looking at the decompression on the cam? i looked thru the plug hole at the valves and the exhaust looks a bit dark around the seat and on my 9 hp flathead it had a bit of a ring that tells me that valve is seating.
today i will tear it apart and take a closer look but i'm leaning on valves and not rings. but because i have it apart i will do rings also being they are cheap and it is apart
but dos this sound more like the valves and maybe the cam decompression?
thanks
thanks
