Will crank with starting fluid, but dies immediately
tronchsr
I have a TroyBuilt push mower, Model: TB105, 159cc OHV, with very few hours on it - ~ 5-10- hours max.
It was stored for 5 years with zero prep-maintenance. The oil, filter, sparkplug are clean, everything looks as clean as new.
I have attached pictures of the engine sticker & model number data plates.
I put fresh non-ethanol (Sta-bil added) gasoline in the dry/empty fuel tank. It would pull easily and turn over. So I tried a squirt of starting fluid - would start the stop running immediately as soon as the starting fluid burned off. Did this 3 times - I suspect it's not getting fuel....
Thoughts from the group about where to start would be greatly appreciated?!! New carb?
Here is the text copied from a sticker on the mower:
EMISSION CONTROL INFORMATION MTD CONSUMER GROUP INC.
EXH FAMILY: FCZHS.1591V1 ECS: EM
EVP FAMILY: FCZHPNHEQCPX, CPXP
DISP: 159CC
ECS: CP
EMISSION COMPLIANCE PERIOD = 125 HOURS
THIS ENGINE MEETS U.S. EPA AND CALIFORNIA EXH/EVP REGS
FOR SMALL OFF-ROAD ENGINES FOR 2015 DOM:12/2015
VALVE LASH(mm):0.10INT 0.15EXH: SPARK PLUG GAP:0.6-0.8mm
OIL: SAE 10W-30 NO OTHER ADJUSTMENTS NEEDED
THE AIR INDEX OF THIS ENGINE IS 3
CHECK THE OWNER'S MANUAL FOR
FURTHER DETAILS
EU: e11*97/68SA*2012/46*3125*01
0 3
MOST CLEAN
10
LEAST CLEAN
8062#
sgkent
give it ten minutes for the fuel to fill the carb bowl and try again.
tronchsr
Will do, thanks.
I looked for a fuel filter like on my riding mowers, but did not find one. I was 'thinking it might not be getting gas ....
With the style of carb used on that engine I’m betting that the float needle is stuck closed not allowing fuel to enter the carb. To find out if I’m right, remove the bolt, 10mm wrench, on the side of the carb bowl. Not the one on the bottom!! If no fuel come out you’ve found your problem. Report back and we’ll explain what to look for next.
tronchsr
I removed the said 10mm screw on the (left_front) side of the bowl, and fuel did flow out for a moment. I put the screw back pretty quickly - but noticed an odd smelling fuel....
It didn't smell the same as the fuel in my gas can....?
tronchsr
sgkent
so old fuel is trapped in the bowl. I'd put a pan under it away from flames, water heaters etc., and let as much out as 2x what is in the bowl to clear out the fuel line and filter too. If it stops then the needle is stuck. Most likely the old fuel will be yellowish and the new fuel clear.
tronchsr
Thanks, I will give that a try....
Scrubcadet10
Moderator
Staff member
i would remove and clean the carburetor.
tronchsr
Alright guys, I removed the float bowl, and sprayed down the inside and bottom of the carb with carb cleaner. There was a significant amount of yellowish buildup all over the inside of the bowl and the covering the float & its components.
After several minutes of this and nearly a whole can of cleaner, there began to be a "flow" of fuel from the gas tank, which I had not emptied of its "NEW" gas nor had I disconnected it from the carb. With it draining/flushing foe a couple minutes, I put it back together and tried cranking - to my surprise it started and ran. Seemed a tad rough, but nonetheless was running.
I let it run for 20 minutes and shut it off for the night. I intend to mow with it this afternoon and burn through a full tank of fuel.
My question is, if I were to remove the carb and clean it; what should I use to soak/clean it with, how much should I disassemble it. I do not have much experience with carbs and always seem to 'mess' something up with them when I do.... should I replace the gaskets outside-small one and inside-large (looks like it also provides heat shielding for the carb). Where do I get the gaskets, if i should replace them??
Thanks a bunch, for all of the assistance so far!!
