winmod21
 - Aug 12, 2021
- Threads
 - 3
 - 75
Hello to all --
Any help will be much appreciated. I believe it's the original Walbro carb (# 75 3349 1205393). Last year it had a broken fuel solenoid wire and was having starting problems, and some very helpful gentlemen here suggested that I forget about the wire, and cut-off the little spring-loaded vertical rod at the top of the fuel solenoid; then to compensate, let the engine idle for approx 30 secs before shutting it off (to compensate or counteract for the fuel solenoids' spring-loaded vertical rod being cut off), (couldn't find the thread).
Anyways, that worked great last summer. But now, the Kohler CV15S is starting okay (sometimes a little hard), and is currently running super great & strong (Skookum !=) without any sputtering or dying. But when I do need to shut it off, for whatever.... then it will just crank & crank & crank, and after a few tries....smell like it's flooded; then if I continually try, cranking it over & over, it'll occasionally make a very loud backfire, followed by a few more intermittent backfires, before eventually starting-up again, though very roughly at first, by which time I'm about to give up for fear of discharging the battery too much.
I do have a spare carb that I purchased last year from SES, but didn't install it - as I was hoping to just use the fuel solenoid off of it, but the fuel solenoid was different (shorter, squatty one - prob fr China), and wouldn't screw on due to the little black wire connector box on the side of the fuel solenoid. So that's when I decided to cut the spring-loaded vertical rod off the top (where it screws into the carb bowl) of my orig fuel solenoid. Which again, helped with poor starting issues, but now I'm having the 'won't restart' problem :~\ ...after mowing for awhile.
Thinking of putting the new carb on . . . but after doing so, are they hard to fine tune for idling & running &c?
Apologies for my long-winded rambling. Any ideas will be welcomed greatly !;-)
Jack
Jack
