Squeaking noise
packy1951
I have a 2019 Hustler 54" SD Raptor with about a 125 hours on it.Lately I am hearing a loud intermittent squeaking noise coming from the left rear. Sounds like metal on metal. I did take the tire off and pour some 3 in 1 oil on the axle behind the wheel hub, but I still have the squeak. Any suggestions, like wheel bearing...etc?
Yup, some 3n1 oil and gauze pads. It's all ball bearings these days. Look at that muck on the windshield.
look for rusty spots where metal can be on metal. look for cracks. look for loose bolts. Become aware of what conditions trigger it and the rhythm.
I’d set the rear on jack stands and slowly spin the rear wheels. You can probably narrow down the area easier that way. If metal is rubbing metal, you’ll see a shiny spot.
I took a look yesterday and didn't notice anything, but will look again.
That's a great idea. I had it jacked up to lubricate, but didn't think of rotating the wheels to see when is makes the squealing./scraping type sound.. it's not a consistent sound like hitting a certain spot on each axle rotation. It could be a change in terrain causing movement between the axle and wheel, but spinning on jacks may show what is going on.
