Rip Kahuna
- May 30, 2022
- 6
Need help! New to forum and hoping someone can guide me
In right direction. I have a John Deere 950R ztrak with Kawasaki 27hp v-twin. I started getting engine code 2-7 low engine pressure. So I quickly shut down when it started to sputter. So I decide to get a new oil sensor sender. while installing new sensor, I overtightened and broke casing. Buddies tried jb welding it. No luck. So I bought the new bottom part of engine, swapped out. And still getting code. Put pressure guage on and had pressure. What can be done to fix this problem? And get this code off and running again. Al see o could it be the computer that read sensors is bad. No sure but need fixed asap. Thanks
