i need help hooking up governor spring for B&S 14D937-0101-G1
keakar
  • / i need help hooking up governor spring for B&S 14D937-0101-G1
i just got a RER snapper riding mower with 10hp B&S 14D937-0101-G1 engine and the guy had zip ties holding the governor because the governor spring was missing
i ordered a new governor spring for it, but i cannot find anything online that shows me where and how to connect the governor spring to it
my knowledge is just with the older intek engines with vertical controls but this is a horizontal control setup like on push mowers and i have no experience at all with those
so can someone please show me a picture of how it hooks up or give a link to help me with info so i can hook it up properly?
you can see the governor spring in picture below
Well can't an all in one image but here probably how it connects.
It is the choke return spring.
keakar
hlw49
Ain't a 10 hp engine. It is a 10 ft lbs of torque which is about 6.8545 horse power.
keakar
ah, ok
i thought it was such a tiny engine to be 10hp, but it says 10.00 on the sticker
the way they play games with those engine numbers now, its hard to tell what they are
ah, ok
Off topic
Who has put that monster on a push mower? If I ever need to get a new engine that one is going on. Or the equivalent Kroller.
keakar
Off topic
its on a rear engine 28" deck riding mower and normally they have a 10hp on the 28" decks like this one so thats why i thought it was a 10hp
the 33" deck rer mowers usually have 11.5hp engines on them but the 25" decks do sometimes have the 8hp engines
This is a 223cc engine with 10ft lbs of torque. Would make a monster push mower engine.
Snapper RER's in 28" normally are 10hp, 30" say 12'ish and the big 33" deck is 14.5hp-16 ish. My 33" Snapper has a 14.5hp 400 something cc Briggs.
The pic below, that engine doesn't belong on a RER.
