- Sep 24, 2017
- Threads
- 288
- 6,901
It looks okay to me, is there hole or buldge in the aluminum on the opposite/outside of the sump?
That the spindle, axle, that the governor runs on is tight in the casting, and the camshaft bearing bosses, especially in the block, is not cracked.The client crank cleaned up with muriatic acid and I polished it to a shiny finish the governor gear never exploded and is intact I am not sure what else to check on that.
