- Sep 24, 2017
- Threads
- 280
- 6,789
Put a line on the pump side, pumped the bulb, in about 6 pumps (which is the recommended number on the plastic shroud) it pulled fuel up to the carb, but the bulb never filled and it never spit fuel out of the purge nipple.Verify carb tries to pull fuel when bulb is pumped. Remove carb and install fuel lines on inlet and purge nipples. Put line to pump side bn in a cup with fuel in it and pump bulb. Should suck fuel and spit it is out the purge line.
