TS 354D Front Grill Melting and Engine Losing Power
AJared
  • / TS 354D Front Grill Melting and Engine Losing Power
I think I may have a dual issue, but I am not positive. The mower is a Husqvarna 2018 TS 354D with a Kohler KT 740 engine. 250 hours on the machine.
Problem 1. The muffler recently failed by separating in half, and the heat shield area became so hot it melted the plastic front grill along the bottom. I replaced the muffler, reinstalled the heat shields, replaced the plastic grill insert, and it once again became so hot it melted the plastic grill insert. I can't figure out why.
Problem 2. Mower starts and runs great for about 30 minutes and then starts missing and stalling. I replaced the fuel filter, gas, air filter, and checked the spark plugs. I also replaced both ignition modules about 6 months ago. Strangely enough, it exhibits this behavior more when turning sharply right or left and will run a little longer if I feather the choke out. This works for a few minutes then it quits completely. After it sits overnight, it starts right up and runs well for 30 more minutes. Any thoughts?
Thanks!
sgkent
I don't know your mower but in general - if the burn inside the cylinder extends beyond the cycle, an exhaust can get very hot. Causes of this can be varied but I will list a few I know.
Too lean a mixture. In a lean mixture the fuel molecules are farther apart. They burn slower and this can extend into the exhaust.
Too rich a mixture. If there is too much fuel present for the amount of oxygen it can cause the hot un-burned fuel to ignite when it is exposed to oxygen present exiting the muffler.
Wrong timing. If the timing becomes ******** it can ignite too late in the cycle to completely burn and finish the burn in the exhaust.
Any condition that causes a misfire, such as ignition issues where the correct air to fuel mixture escapes the cylinder un-burned, and is ignited inside the exhaust stream by the next charge.
Leaking exhaust valve where the burning mixture is allowed to escape prematurely
Personally I would start with a full tune up, new fuel and air filter etc., and make sure the valves are properly adjusted. I would do a compression test as well. If there is still a mis-fire such as you describe, I would look for vacuum leaks, plug wires that might be bad, etc., and find the cause of the mis-fire. That might fix it. If you take it to a shop, make sure they are really qualified to find these kinds of things, and not just a shop that throws parts at a problem. It could be the carb so I might study up in the factory service manual how to rebuild one. I would not just start taking things apart.
AJared
Great thoughts! Thank you!
