I give up trying to explain things. I haven't spent the last 13 yrs cleaning various carburetors just for my health. It like saying since I don't smoke so I cant get lung cancer.
I did quit using the toxic chemical cleaners in favor of soap and water.
You mean you actually got the MTD carb kit to fit. Almost every one that I have had to install there is some part in the kit that is incorrect for the carb. Correct part number per IPL but the float valve is wrong, or the wrong bowl gasket, or some other part that you need but can't use.It $55/hr here. What worst is the MTD carburetor that even the rebuild kits didn't fix as it burning too rich and I even used the smaller jets. I ended replacing the carburetor. Or the carburetor on the Honda generator that I having to replace due the plastic needle seat leaking and not replaceable. Hopefully the second carburetor is okay. At it is not broken like the first one.
YouTube is a joke at times.
if you are full time and not a semi-hobby I would raise /hr price. Add up the hours you loose looking for parts, checking inventory, invoicing, keeping your books, doing your taxes etc..All the dealers around me are right at $100 an hour. I do ok at $40 but i am considering going to $50. I have a lot less overhead than the dealers.
I am pretty much full time spring till fall. I retired at 61 a few years ago and took the shop full time. I had been doing it as a side hustle for 30+ years. My overhead is almost no existent and no mortgage and no debt. At $40/hr i actually clear more profit than dealers at $100/hr. I also run a one man consulting business so i have plenty of work. In fact my accountant told me to buy some more stuff that is deductible to help with taxes so i am really upgrading my woodworking tools.if you are full time and not a semi-hobby I would raise /hr price. Add up the hours you loose looking for parts, checking inventory, invoicing, keeping your books, doing your taxes etc..
