corvairbob
i just got this mower the other day, the guy claims it has a misfire on the left cylinder looking at the front of the engine. however, i can pull the plug wires off one at a time and the engine still runs so that tells me there is no misfire. but it stumbles kind of like it may have a dirty carb. when i start it i need to have the choke out about 1/3 so it will run smooth. then after a while, i can push it in but to be honest, i have not yet ran it for more than 10 minutes and it is 60 deg out so that may change as it warms up.
but when cold started it does do the normal surge as most do until they do warm-up. but to save time maybe someone can tell me if this is a normal thing? i'm thinking the guy that sold it to me did not realize that it may have a carb issue and just did not want to mess with it. he already put a 20 hp engine on it a few years ago it came with the 18.5 engine. so i do not mind digging into the carb but before i just wander into something that is as simple as an adjustment i figure someone here just may have the fix. the mower is in real good shape oil is clear new filter tires are good frame is clean so i'm thinking he did take care of it and service it when needed. and the new engine kind of tells me that also.
thanks
thanks
