Craftsman G5500 fuel trouble
Need you to post Engine Manufacturer, if B&S post Model xxxxxx, Type xxxx, Trim xx & Code xxxxxxx from engine top or side of engine.
Thank you Mark, I go this questions answered, next time I will make sure to post that information.
People forget that they are there with the mower right in front of them & we are her with a screen full of words.
Even worse is different people use different words to describe the same thing which may or may not be the manufacturers actual part name so it gets very confusing trying to work out what some people are talking about .
The relevent numbers allows us to pull the IPL and then work out what you are talking about .
For an engine it is the full engine number
For a mower it is the model number & serial number from the ID tag, not the decal on the side of the hood which has no meaning whatsoever as the same model can be made by several different factories and in some cases may only exist in one state because it is called some thing different elsewhere ( marketing ) .
I hope you stick around here. I enjoyed your witty responses.
I will, and I will also take the time to learn the etiquette for posting. Not easy for a new person to step in not knowing the lingo, numbers and such. You guys have saved me a few hundred dollars already, so I tip my hat to that! Thank you again.
