Turbo Dragon
Hello all, I really need some help. I just cut grass last weekend at one of my properties, mower ran great. I tried to use it again this weekend, now it will spin over, but won't start. It started spitting gas out of the exhaust, so I pulled the plugs, one plug looked burnt, i went ahead and replaced both plugs, same thing, I put at spark tester on the coil packs, both coil packs are working fine. I pulled to fuel injectors out, spone the motor, both injectors shot fuel. Has plenty of gas and oil, and air filter is still almost like new. Does anyone have any idea what could be the issue? Only other things i could think of, are O2 sensor or MAP sensor.
Thanks in advance
Thanks in advance
