Need help identifying an OEM tecumseh lawnmower carb that came off a snowblower.
skyline0964
  • / Need help identifying an OEM tecumseh lawnmower carb that came off a snowblower.
I'm trying to identify a tecumseh lawnmower carb that came off a snowblower. I have scoured the internet and have had zero luck... The bowl nut is part# 632385. All I'm seeing is the bowl nut is used on CCR Toro's. NOTHING with a push to prime. Any help would be highly appreciated.
Look for the manufacturing number and then post it.
But I think is a Dellorto carburetor which I have no info on.
Looks to me like a Tecumseh #640278, but I’m running into a memory problem. Looking at your pic I don’t think that that carb came on a snowblower engine, as it is most commonly used on mower engines. Are you sure that it is the original carb? Do you have any numbers off the engine ID tag?
skyline0964
I know this is a mower carb. 640278 is not the correct carb. carb 640278 uses 640050 as the bowl nut. no bueno.
Now I’m totally confused as to what you are looking for. I identified the carb in your pictures. Are you trying to find a lawnmower carb which uses specific snowblower carb bowl nut?
skyline0964
No.. I'm trying to identify the carberator part# man. That carb you listed it similar but it has a manual choke lever to connect a linkage which mine doesn't have.
Find me a tecumseh push to prime carb that takes the bowl nut with the huge main jet. It's a fixed jet (non adjustable) so I'm thinking it came off a machine from the early 2000's or later. possibly a 2 cycle engine.
Good luck in your search. Finding the specific carb which uses a specific main jet is not easy. Just as your carb came from a mower, I’m willing to bet that the jet came from a blower. Probably a “fix it job” done by a “DIY GUY” from his “ I’ve got something that will work” scrap box. If you find what you are looking for, I recommend you also go buy yourself a lottery ticket.
Done a little more digging here. It seems to a series 6 4/2 cycle carburetor. Try looking at the 632466 which was replaced by the 632795A.
Star, I found that one also, but the OP has stated more than once he wants a fix-jet non adjustable carb.
