I appreciate the perspective you guys have nor am I trying to stand my ground. I've dealt with the public in various capacities myself so understand that what comes from people is definitely not necessarily how it is. In this case, I very much recognize my limitations. I hesitated to ask in the beginning because these are very, very basic questions but I asked because I didn't know the answers. I didn't find much conclusive on the net.
I'm far from a penny-pincher but I also prefer not to throw $ out if I don't have to. If the mfr recommends 100 hours then worst case 100 hours it is - I'm pretty particular about these things. However, if the pros are seeing in real life that it's risky to wait until 100 and I should do it at 50 (or 30, etc), well, 50 it is. We're talking a few dollars on an almost $10k investment.
For anyone who wants to see,
https://www.ferrismowers.com/na/en_...ications.downloadmanual.5109508_C_LO.pdf.html is where I found the manual (Ferris product page link to manual) and
https://www.kawasakienginesusa.com/sites/default/files/manuals/FT730V-EFI-English-Spanish.pdf for the Kawasaki manual. I'm not sticking to this - if you guys recommend "real life" to do it more often, I'm definitely going to do it. I don't want to cause myself hundreds or thousands of $'s in damage for not doing a $30 oil change or something stupid like that.
Back to the dry lithium grease spray (Blaster? Lucas Oil? Red-n-Tacky? Doesn't matter?) ....it's probably like everything else but since you encouraged the asking, I will dry lithium spray grease...assume that's for the stuff here (control handle pivots, seat plate pivots, etc)?
assume this is like bicycle chain lube?
amazing this small machine requires so many different types of grease.
The hydraulic oil and the standard engine oil are pretty well called out in the manual - hydraulic is 20w50 (Ferris manual) and the engine oil is 10w40 (Kawa manual).
thanks again for taking all the time you've taken. If any of you run businesses anywhere near north central Florida, I would gladly take my Ferris to you for service if nothing else but to say thanks.
