artemjemmy
- Jul 9, 2018
- 72
I have a homelite super 2 (the one with a 2 piece plastic clamshell), that will run great at open throttle, but when you try to let it idle, it gradually decreases in speed and dies after about 10-15 seconds. Idle mixture and idle speed adjustment make basically no difference, unless you have the idle speed set so high that the clutch engages. When I go to restart it, I need to turn the choke on all the way, which makes me think the metering cavity ran out of gas? I already replaced the needle and the fuel pump diaphragm and metering diaphragm, and adjusted the metering arm with the proper walbro tool, with absolutely no change in the symptoms.
