So if you run double blades this will cause more strain etc.??Mulching blades do well for their intended purpose. The other side of that is being the sail is higher, it will require more to spin them, more gas, & more strain on belts, etc.
High lift blades are harder to spin than mulch blades. High lifts move more air...Mulching blades do well for their intended purpose. The other side of that is being the sail is higher, it will require more to spin them, more gas, & more strain on belts, etc.
