LT1045wrh Active Member Sep 24, 2022 #12 Just torqued mine down to 80 ft lbs since I couldn’t find torque specs in the manual. Used the torque from other mowers I have. wow if I loosen them up to they might fall apart!
B biller Member Sep 25, 2022 #13 SeniorCitizen said: Did biller get his Murray repaired to his satisfaction? Click to expand... Yes, I did. Fancy ($$) paint I applied under deck is gone already. Cuts great again. Thanks all for helping.
