davekk_fishing_fan
Hello,
Looking for some help here....
I have a Snapper NXT22875EE Model #7800752 that has a battery starter. I use this mower at a lake house and I do not have the ability to limit charging so it often will not start when I need it. Once it does starts tho, it runs great. I have replaced the charger and battery twice as it often gets over charged and the battery will not hold it. The past few times I hit the breather with some starting fluid just so it will kick on the first spark. In a pinch last week I wrapped a rope around the top and pull started it. The engine probably only has about 20 hours on it but it is several years old.
I would like to convert this to a pull start and not use the battery start any longer.
Does anyone know if it is cost effective to convert this or should I just test the system and keep buying batteries and chargers?
Thanks
Dave
Thanks
Dave
