BWH
That sounds like a good move I just don't know what else to try, I was vacuuming leaves yesterday also in fact they were so deep at times they come up over the front of the deck but it was perfectly clear behind. The only place where it has a tendency to blow some debris around is on the driveway when I try to clean that up it picks up a lot of the leaves but there is some air that escapes the deck without being in the lawn.
I believe the Woods decks are basically the same as Grasshopper as I remember the early model decks were not as deep as my current 61" deck which is 5.5" deep, I believe my 1990's decks were 4" in depth Grasshopper says the deeper decks enhances air flow.
