- Nov 29, 2014
- Threads
- 65
- 24,783
Don't do may pressure washers so I am at a bit of a loss here.
Got an RMW 22G24 pressure pump mounted under a 4Hp B & S that came in for an engine problem which turned ut to be a dud auto choke
However the pump leaks everywhere from the overflow holes around the sides .
So it was no surprise when I found the 3 water seals trashed.
Now the customer bought this unit on Evilbay supposed to be a genuine brand new B & S branded washer
HE has never opened it up & I am the first person supposed to have done so
Now the water seals were trashed, no big problem to replace except they had been glued in with silastic as were the check valves.
My question is in the diagram below there is a plug shown as item # 64.
Now this is not easy start and the plug is not there
Do I need to replace it or can I reassemble as I found it
AR pump prices ar through the roof down here, the water seals will be $ 93 ( Aus ) delivered and the plug wil have to come from the US so will end up costing another $ 50 by the time it gets here
I am geussing it is just a plain rubber bung, so could I just cut a plug from thick rubber and shove it in ?
