Pete-MKCS
Owners of the Husqvarna Zero Turn mowers, do you have to push the deck level adjusting hard to set it in the No.1 and No.2 position. Most mowers drop to those positions using just gravity, but mine seems to have a lot of tension against the lever when lowering the deck to the 1 an2 position. So, is this normal?
