Shootertexas
- Jun 18, 2020
- 26
I need ya'lls help again.
After replacing the rectifier, oil, oil filter, fuel filter and air cleaner it ran like a top. My friend came and got it and he went to mowing the grass at the church he pastors.
It ran according to him, great for about 45 minutes, and all of a sudden it went into and extreme over speed condition. He immediately ran it up on the trailer, about 45 seconds after it started the over speed and killed it. Somewhere in between the time it started to over rev and the time he got it on the trailer he disengaged the blades and it threw the belt off.
I have it now and am trying figure out if its an internal or external problem. I don't believe the servicing had anything to do with it as nothing on the linkage was touched.
I have looked and the governor shaft coming out of the engine and and it appears to move with the lever so I believe it is tight.
There is however some in and out movement of the governor shaft, is that normal?
Probably a long shot but I was contemplating taking the cover off the carburetor to see if possibly the butterfly fell off the throttle...maybe a stupid idea.
I will say the throttle cable is very had to move, so much so he broke the paddle off and there is only a nub sticking out to try and move the throttle.
