Coprhed5454
- Aug 27, 2021
- Threads
- 1
- 4
Hi all! Looking for some help on a John Deere LT166.
My neighbor gave me the mower with a blown B&S 16hp v-twin. I purchased a good used 24hp B&S v-twin Intek to replace it. Got it bolted up and all of the wires connected and started the mower. It ran great with now issues. While mowing, I did notice that the button to keep the PTO engaged while traveling in reverse was not working, the blades stayed engaged without pushing the button. The next time I started it, it started fine again. I had to shut it off to put the cowling back on and when I tried to start it again, the solenoid clicked but the starter didn't engage. I replaced the starter with the starter that was on the mower before, that tested good while off of the mower, and still nothing but clicks. I have checked all battery and ground connections and everything seems to be connected and getting good voltage and ground. I have noticed, however, that after trying to start the mower, I am getting about 2.5 volts on the starter housing. I found this out when my multimeter prong accidentally touched it when checking for 12v at the starter connection. Is this a sign of a bad ground somewhere? I am getting 12v on the solenoid trigger pole and ground on the solenoid ground pole as well as 12v at the starter.
Any ideas? Any help is greatly appreciated.
