Oskar Blue
Long story on this one. Mower was running fine, and broke a deck belt for the blades. I knew already that PTO was going bad but just never got around to replacing it. Got a new belt and replaced, and noticed the drive belt was off the pulley and in between the pulley and PTO. Mower still moved but was sluggish and that I figured would explain that. put it all back together and was testing the mower out and it started to make a squealing sound down near the PTO. made 2-3 passes with the mower and it quit running. took the deck out and did some testing on the PTO. confirmed it was bad. Replaced the PTO put it all back together, and it still won't start. No spark to the plugs. Tested all of the switches, park brake, seat switch, PTO switch, all test ok. I couldn't hear the fuel solenoid click and at this point I was sure it was the interlock mod.Bought a new interlock module as it was looking like this was the issue from all of the things I've read. before I replaced the interlock I disconnected the kill wire to the mags, still no spark. Broke down and replaced the interlock since you can't take it back after the bag is open and still nothing. So its not the Interlock mod. What else am I looking for possibly that would cause no spark condition. Battery is brand new and it turns over just fine just will not start. Any help or ideas would be appreciated , Thanks
