I you want to diagnose it there are two fairly simple things to do
1) fill the tank right up to the top of the filler neck then go trim
Problem goes away till the tank is say 1/2 empty then you have a fuel line problem
2) buy a red inline spark tester fit it , tie it out of the way then go trim
Watch it when the engines starts to play up
If it keeps on flashing the same while the engine is missing then the coil is working fine .
Note this does not confirm the spark is timed properly, just that it is happening .
Most times bad seals on a 2 stroke manifest themselves by the engine being near impossible to start if it has been sitting unused for a couple of weeks but once started it will start & run fine but be low in power and reving at the wrong speeds (usually to fast ) for the throttle position .
A classic sign is continually having to wind the throttle stop open to maintain an idle because it is sucking air through the seals & not the carb.
You can only confirm this by doing a crankcase pressure / vacuum test
To do this you need both a 2 way pump , blanking plates , an input spiggot ( usually through the spark plug hole ) plus a fair bit of time & skill.
I charge 1 hour to do these test for customers and many times that would be a loss as some are really difficult to access .
However when presented with a machine like yours I follow the proceedures shown in the Joe Pace videos and start with the tank & cap, fixing each & every problem as I come across them .
Not uncommon to find a bad fuel cap, bad tank vent, leaking fuel line , leaking fuel grommet & partially blocked fuel filter , before you get to a varnished up cab with a blocked internal filter .
People seadfastly refuse to maintain hand held 2 stroke tools .
This is not helped by most of the owners manuals having wrong or no long term storage information even if the owner is one of the 2% who actually read it before they start using the tool.
