Electric PTOModel number please ?
Electric PTO or manual PTO ?
I pull the Yellow PTO button by the key, I unplugged it and the blades continued full speed no changeElectric PTO
Don’t know about a clunk but when you turn the key on it starts the engine and mower deck with the PTO switch up or Down it doesn’t change it.when sitting on the seat & key in the on position ( engine not running )
If the PTO goes Klunk when you push & pull the PTO switch then the bearing is shot
If the PTo goes klunk when ever you turn the key on & off then you have wiring problem / switch problem
I will try the key the the PTO switch to see witch one makes a clunk soundDon’t know about a clunk but when you turn the key on it starts the engine and mower deck with the PTO switch up or Down it doesn’t change it.
I tied it both ways and never heard a clunking sound, i had my girlfriend do it with me laying with my head next to the clutchI will try the key the the PTO switch to see witch one makes a clunk sound
