Those anti afterfire solenoids, DO NOT control fuel flow into the bowl, or into the intake... carb needles will still fail, and carbs with those solenoids will still fill up a crankcase with gas if the needle or float fails.
all it does is block off the main jet... gas can still flow up in vent passages into the carb and fill up a crankcase.
