george2018
- Nov 25, 2018
- Threads
- 3
- 17
Hi all took apart a lawnmower with a tecumseh engine ( TVS120-63920L) the cam has a timing mark the crank has none. It has no bevel, dot nothing. it is the type where the gear is pressed on. Even if the gear was mounted upside down you can't see underneath because part of the crank prevents this. So now what? I'm ready to throw it in the trash
