OK So here I am again, this time I would like to say ThankYou to everyone that replyed to my question. I read all the replys and just used all the information to make a judgement as to how to go about my repairs but again Thank You all. Seems like this will be my go to site for questions about my lawn stuff if needed.
So this is how and what I ended up doing. As I had posted before I did replace the gasket diaphragm kit and sprayed with carb cleaner still didn't run kind of tried but never got it to really be a runner. I ordered the full kit from Randy and also did get a whole used carb from Ebay. After getting all the parts together I went ahead and completely rebuildt my original carb. This time I also used my ultrasonic cleaner to be sure things really got cleaned out. Got time this morning to see how things worked out and with a little messing around the thing started and I got the carb adjusted somewhat in that it would run on is own, wouid accelerate to HI speed with out any falling out so let it cool down and tried it again. Started right up but did have to tweek the adjustments just a bit as I believe someone said that may happen. At this point things are good to go.
One thing I would like to say to lit others know when I set up my cleaner I used Super Clean to do the carb I did mix it with water and used a plastic bag but this stuff stained the carb instead of nice and polished looking its kind of a very dull black/brown color. Guess this isn't going to matter because its working great and is under all the covers so no one sees it.
THANK YOU !!!!!
