LT1050 Mower puking oil
John1954
2005 Cub with a Kohler Command engine. Kohler CV730, 950 hours on engine. Started the season with a small oil leak between the lower pan and the main block near the oil filter. Got worse and found the leak at the gasket. Replaced gasket and lower shaft seal. Ran it for about 20 minutes and the lower seal blew out. Engine crankcase appears to be building pressure. I have read there are breather reeds in the engine which can break causing this problem. Also there may be a breather behind the carb. Where are the breather reeds located? The Kohler manual is a bit vague. Is this an easy repair? Does this engine also have a breather behind the carb? Thanks for any advice.
How does oil on dipstick look? Does it smell like gasoline & past full mark? Look at valve {rocker} covers topside & check breather hose to air filter.
See page 18 troubleshooting,
How does air filter look? Need to be replaced?
Very little oil on dipstick mostly on the driveway, no smell of gasoline. Valve covers both sides are dry at gaskets. Breather on right side valve cover is not clogged, neither is breather hose. Previously looked at page 19, Kohler guide says breather reed broken as #1 cause. Unfortunately this manual you are referring to does not identify the location of the breather reed(s). I did a word search of the manual. Can someone tell where they are located and how difficult are they to replace??
